Patch the holes in the truck that I cut months ago when I installed urethane bushings to remove the cage nuts for new bolts. Fixed the sloppy front sway bar end links.
Is this a club I can join? I feel like I could be president
What an awesome build! I'm absolutely loving the Caddy 500 swap!!!!
You can add me to the Anti-LS consortium. I'm just breaking in an Olds 403 I built for my Cutlass and am so Glad I didn't fall into the "LS swap it" group think mentality.
20 years ago at car shows it seemed like the LT-1 swap (from the C4 Corvette) was all the rage. There's definitely been 10x the number of LSx swaps than the old LT-1 swap, but I wonder if 20 years from now if the LSx Swap will be looked at in the same way.
"LS swap mentality"??What an awesome build! I'm absolutely loving the Caddy 500 swap!!!!
There is, low end torque. I am just not impressed with the Gen 3 or 4 motor, maybe because I drove them stock in trucks. The only thing good about them was better mileage in trucks and anything was better than the GM swirl or peanut ports a few years earlier. I just don't get the appeal in old cars till gas is $8 a liter. Love the idea of the bone crushing torque with some hp sprinkled on top in this build. Mileage isn't a concern keeping the tires above the belts is😁."LS swap mentality"??
If cheap, reliable, powerful, compact, and fun V8s lump me into a less than desirable group can I be the ring leader?
I'm all for originality but there has to be a payoff somewhere.
Low end torque.There is, low end torque. I am just not impressed with the Gen 3 or 4 motor, maybe because I drove them stock in trucks. The only thing good about them was better mileage in trucks and anything was better than the GM swirl or peanut ports a few years earlier. I just don't get the appeal in old cars till gas is $8 a liter. Love the idea of the bone crushing torque with some hp sprinkled on top in this build. Mileage isn't a concern keeping the tires above the belts is😁.
Excluding drivetrain from the transmission back, it’s possible to do it cheaper with a LS.I’m not sure what stock motor your referring to that has the same torque as a 5.3, but you certainly are talking about a 500 Cadillac.
With a cheap 4.8 or 5.3 you will need a turbo to get north of 500hp. By the time you get a 4.8 or 5.3 to run low 11s or high 10s, cheap has become subjective, and no matter what fast is always subjective. What do you consider fast?
To duplicate my car from bumper to bumper, with a 1000hp transmission, driveshaft, and rearend, and to be just as streetable and just as fast, in both a straight line through the curves, could not be done much if any ‘cheaper’ with an Ls engine.
