Thanks for checking out the thread guys
Well, it has no plugs right now. I've just rolled bits of paper towls into a ball and stuffed every opening of the engine.. Not that this is 100% air-tight but I think it helps. It has no exhaust headers either.
I will think about spraying some of that stuff into each sylinder next time I'm there. Thanks for the tip.
Yeah I had a plan moving to Spain but its not do-able in my situation. Will just find a house in this cold country with a nice garage
🙂 Will finish the project there. Will take som photos of that when I have moved.
It has been in the container since the end of November last year.
And yeah it has been hard work. Even lived at a workshop smokers-room for a period when I worked on it
And parts were mostly ordered from USA, and I had to take the bus to the post-office and carrie them on my shoulders. I have no other car than this
Here are some photos from when I "packed" the car together temporary to move it more easily.
Cleaning the th350
Will get new front arms, springs, shocks, bushings, steering linkage, rear brakes kit etc..
I just put some 4by4's in between the arms and frame to get some ground clearance as you can see was needed
Will pull out the transmission later and give it new gaskets and paint. Also the crossmember will be either swapped out, or modified for dual exhaust.
This was an epic moment for me. Almost shed a tear when the chassie was back on.
Just did not have time to bend and mount brake and fuel lines first.. Will be a pain to mount with chassis on I guess.
