12 is the diagnostic mode code. Does it just flash 12 over and over, or does it do it 3 times then another code?It's giving me a code 12
Over and over 12 that's it. I sat there for a while trying to see if it would flash anything else12 is the diagnostic mode code. Does it just flash 12 over and over, or does it do it 3 times then another code?
No I haven't 🤔Have you tried disconnecting the battery..
Electrical gremlins. PITA
I bet it is the ignition module also. It doesn't take much to fry that thing.Have you checked the ignition module? It is located under the distributor cap. I had a 3.8 get weak spark one time and it wouldn’t run. Changed the module and it fired right off.
life gets in the way. or he sold the car and has left us forever.From what I've seen, the OP hasn't "checked" much.
