1982 Monte E85 Blow Thru Procharged SBC Build *PICS and VIDS ADDED***RUNNING***
I have no idea about using a bump switch. I really don’t I tend to use one, but I’ll probably change mind later lol.
I’ve found that it’s much easier to let the ecu control everything possible - less things to go wrong,and changes to settings are very quick. Also a learning curve and it’s easier to learn with less things going through the ECU.
No matter, can’t wait to see it running!
I ]t was informative. I watched it & would have watched another if you did more.
Thanks. I have no problem doing it if it gets a discussion going or if anyone has something in particular they'd like to see.
With a bump you need to send the transbrake signal thru the ecu so the ecu can pwm the TB solinoid when you press the bump button. I have nothing for my ecu to do when I press the trans brake so no need to waste an output on it.
Running out of things to do without the intake. Hopefully I get it back soon.
I was trying to mess around with the OE radio bezel and just said screw it and made this piece. The right outlet is a USB port that will go to the ECU. The right outlet is two USB ports for charging.
Then because street car
An update!
My cousin started on fabricating the intercooler
Also got the intake back from FFE. They also vapor hone blasted it for me. Looks killer.
