1982 Monte E85 Blow Thru Procharged SBC Build *PICS and VIDS ADDED***RUNNING***
melloelky
4,157
9,551
mass
growing up my dad threaten to install something very similar under my gas pedal..if i kept screwing up,that bolt would get taller.. :sneaky:
wingnutks
420
1,314
Very interested in how well this works. I’m hoping to need some similar soon. I was thinking of a similar setup but using a 3/4” bolt.
Should work fine. Trz does it the same way. 1/2" should be OK.. 3/4" probably over kill
bracketchev1221
1,406
1,642
I started with my limiters at just where the top of the tire started to tip in when I raised the front end. I started with the threaded rod type shown and then changed to the s&w race cars kit. Uses a threaded rod with a big disk on the bottom side and a rubber bumper in the frame. Was a little more forgiving.
wingnutks
420
1,314
I dont think they make that anymore
Edit: actually just found it. They use a 5/8' bolt for theirs. I might put a rubber snubber on the bottom of the bolt or some. PITA with there kit is because it has to be put in from the bottom you might need to take off the upper control arm to get it in.
bracketchev1221
1,406
1,642
Yes they still have it. I don’t remember how they went in. It was almost 20 years ago when I put them in. But I did go 1.21 in 60’ with them.
wingnutks
420
1,314
What you guys think a good asking price would be for all of these gauges? They all work mint... They actually are wired to a plug so they plug right in to the stock gauge plug.
mclellan83
4,244
9,411
Pgh, PA
I'm not the one to ask, I apparently think these are worth more than they are because I have been sitting on them for a while now
5,697
12,180
Is the speedo cable driven or electric?
melloelky
4,157
9,551
mass
i think they were big money back in the day i remember seeing them in a gmpp catalog but just the fact that they're already wired to plug into the dash already is a good selling point
