1982 Monte E85 Blow Thru Procharged SBC Build *PICS and VIDS ADDED***RUNNING***
wingnutks
420
1,314
Fan fix has worked. Went for a cruse when it was 90f and highway Temps at at 192f...and Temps come down when I get off the highway. Today it was 80f and Temps were just under 190f. I'm sure if I got my trans cooler off the radiator it would help lol.
Also my tune is doing pretty well I think
She is pretty thirsty
wingnutks
420
1,314
Amazing what a little more air flow will do.
Definitely more than a little. I bet this fan pulls 2.5x more air. I still think the radiator is a bit junky tho.
5,711
12,223
Does it feel like you're making more now than last year? Asking because of the 875 lbs/hr of fuel flow.
wingnutks
420
1,314
Can't tell. At 6500rpm and 11.1psi it is using a touch over 880lbs/hr. On engine dyno, same pulley, it made 920hp at 6300rpm and 15ish psi
Also on dyno I was at about 24* @15psi. Right now I'm only at 20*@11.1psi
wingnutks
420
1,314
E85 is generally 1:1 lbs/hr to HP with an optimized AFR and timing. So it's making steam like it was before.
That's a win!
Are you going to dyno again?
That's what I have heard. However I'm assuming that the 4psi I am "loosing" is coming straight from intake air temp drop from adding the intercooler. I would bet my iat non intercooled were over 200f...now they are less than 120f for sure... Might be lower. When I had the engine on the dyno last year the larger pulley made 11-12psi and going from 24* to 26* picked up almost 50hp. I think with the 12psi of intercooled boost I'm making now, 20* is crazy low. I bet if I add timing my afr will lean out from 11.5 it is now, requiring more fuel.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
You're likely bang on with the intercooler and charge drop. I assume your system will add fuel as AFR drops? But You're probably right about that too, probably a couple tenths up in AFR. With that intercooler and better fuel control you can probably get a degree or two more agressive on top too. Really spice it up.
5,711
12,223
I think you’re into plug reading territory. A blow thru will take a lot more timing than most anything else.
wingnutks
420
1,314
I don't think so. It's an 9.2:1 intercooled sbc on e85. I'm pulling almost 16* of timing for 11psi. I bet I end up at 26*. Blow thru is definitely better than non intercooled efi, but the intercooler on efi makes it close.
