The 355 really sounds good with that big of cam, not sure if you fired yours up yet up it sounds good, really choppy idle. You running 1/8 mile or 1/4
Blue86Monte said:with 4.10s and 26x10.5 mt et street i run past the trapts at around 4800 and thats only running 8.20's. It's going to be a screamer on the top end with higher gears
he was in the 1/8thCrazcnuk said:Blue86Monte said:with 4.10s and 26x10.5 mt et street i run past the trapts at around 4800 and thats only running 8.20's. It's going to be a screamer on the top end with higher gears
What are you using for a transmission? Have to be in OD to gt those numbers!
Running 28x10.5 MT ETs and a TH-400 I was hitting the 1/4 mile at 5600rpm
Blue86Monte said:Last saturday was the first time out with the car and we got it down the 8.25 in the 8th. Still only has 30 degrees of timing and only has a 1.91 60 foot. Your car should be a runner once it's done. If you like the loud noise, i put a set of pypes header back from my headmens, they have a good tone, but they are LOUD!
Crazcnuk said:"he was in the 1/8th"
Ah, that would explain it, we don't have any tracks that short here!
"30 degrees? must be at full vacuum, im running 15 degrees at idle ~1000rpms"
Vacuum advance has nothing to do with racing. In fact, you should disconnect the vacuum advance at the track.
30deg is pretty low, though, should be around 36 all-in by 3200rpm (or so)
