85_SS said:I'd like to see the VIN/serial number stamping as well - I don't know much about factory prototypes, but if that matches what typically happens with such cars, you're one step closer to authenticity
Randy_W said:I don't see a thing about that car that doesn't fit exactly what PMD would have done in that situation, it wasn't a show car, it was a prototype, for testing a nose and spoiler to see if they could the results they wanted without spending the big money on the bubble glass. The VIN, EX4788. It fits into normal GM nomenclature for such cars, the white trunk doesn't mean a thing, the car was painted in the specialty shop where the nose and trunk were done, common practice, I'd say it's real.
Well, let's start with the miles, super easy answer, GM VIP's could put a manufacturer's plate on a Go kart and drive it if they want to. The vin is standard fare fore cars not intended for production. Now to that little spoiler and how it might help. In the old days we called it moving the bubble. That meant that by extending the trunk back and/or up into the slip stream, you could actually move the air stream higher off the rear of the roof therefore cutting down on the low pressure area behind the back glass. That reduces the drag coefficient making the car faster on straightaways. Now obviously, if this was truly a PMD prototype, it didn't work well enough as the bubble glass showed up shortly after this car. I have no idea if the car is real, but nothing about the car precludes that, as I said before. When I say things like that I'm not pulling info out of my *ss, I'm telling you from what I've known to have been facts in the past. GM and all th rest did stuff like that in the 60's and '70's, why not in the 80's? This car might be a total hoser, but nothing about the car I see or his info proves that to me. I assume he or someone has the bill of sale from GM, if so that is likely all the docs that exist. If nobody can produce the bill of sale, then it's just a leap of faith.pontiacgp said:if it is a prototype and was used for testing and it comes without a title then why does it have over 15 thousand miles...the main reason they put a long window in the back was to stop the rear of the car getting lifted from the vacuum that was created by the flat back window, which in turn slowed the car down. Even the rear spoiler on the nascar body didn't help that problem so I don't see how that low rear spoiler had any effect on the problem they had..plus with the suspension on that car I don't know what testing they actually did with it sitting so high..
