So I have my console painted and installed and I have my shift indicator wired, I was able to keep the function of the factory column arm so the dash shift indicator works with the floor shift indicator and also keeps the factory reverse lights and neutral safety in tact.
The upholstery I ordered a couple months ago from StockInteriors.com for the rear seat finally came so I stripped off the pillowtop upholstery and installed the new upholstery made by ACME the same material that Cerullo uses on their buckets seats.
The bottom cushion was a basic R & R but when I removed the upholstery for the top I remembered that the foam is designed with recesses for the pillowtop cushions so I had some bottom seat foam that I cut to fill in those areas and then used 3M Super Adhesive to glue them to the other foam so after doing a mock up and fitment I finished the install of the new upholstery.
And then with the new rear seat installed.
