1987 Cutlass Build
Control arm update, got these back from a buddy of mine that welded up a plate set i bought years ago from Gbody parts i think it was. Not only did he do some great welding on them he put box tubing around all the sway bar holes which stiffened them up even more. Now i just have to throw some POR15 on them and install the bushings and they should be good to put back on the car
Rolling Coal!!!!
He should go with a W25 hood and route two pipes, one at each opening. Then paint it like a Dragon, smoke coming out the nostrils🤪
Reactions: fleming442
I'm patiently waiting for the burnout video.....:popcorn:
I think this thing should be a burnout king if nothing else. I think i have some old tires laying around 🤔
Reactions: Injectedcutty
I cant quite make up my mind on the exhaust. With the position of the turbo from past experience with the 6.5 in a Gbody the "easiest" route is out the passenger fender just behind the wheel. Although what i am going to try and make work is a understated 3 inch pipe out the back and exit just behind the passenger tire, just enough so you can barely see the exhaust pipe. I have thought about a combination of those as well, the 3 inch out the back for daily driving and i could put a cutout on the downpipe to an electric exhaust valve to direct it out the fender when i wanted to roll coal or just generally look like an idiot.
What is the supercharged 3800 going in?
