1987 Cutlass Build
84dragcutlass
1,189
1,507
North Vernon IN
Control arm update, got these back from a buddy of mine that welded up a plate set i bought years ago from Gbody parts i think it was. Not only did he do some great welding on them he put box tubing around all the sway bar holes which stiffened them up even more. Now i just have to throw some POR15 on them and install the bushings and they should be good to put back on the car
8,827
7,783
Rolling Coal!!!!
8,827
7,783
He should go with a W25 hood and route two pipes, one at each opening. Then paint it like a Dragon, smoke coming out the nostrils🤪
84dragcutlass
1,189
1,507
North Vernon IN
I'm patiently waiting for the burnout video.....:popcorn:
I think this thing should be a burnout king if nothing else. I think i have some old tires laying around :unsure:
84dragcutlass
1,189
1,507
North Vernon IN
I cant quite make up my mind on the exhaust. With the position of the turbo from past experience with the 6.5 in a Gbody the "easiest" route is out the passenger fender just behind the wheel. Although what i am going to try and make work is a understated 3 inch pipe out the back and exit just behind the passenger tire, just enough so you can barely see the exhaust pipe. I have thought about a combination of those as well, the 3 inch out the back for daily driving and i could put a cutout on the downpipe to an electric exhaust valve to direct it out the fender when i wanted to roll coal or just generally look like an idiot.
500/600
1,167
2,638
West Virginia
What is the supercharged 3800 going in?
