Yes exactly. Think about it, no matter how different these frame mounts are,they can't be that far off..
Just measured up both brackets. 2 1/2" Picture of the passenger side:
Doing that makes your motor sit higher. Did that result in any clearance issues for you?No I meant the holes for the clamshell. Sorry I should have specified. You might have already done that though
Just have to throw this out there...Do you have the clam shell mounts swapped side to side?
All the small block Chevy mounts I've used have a captured nut on the passenger side clam shell, the fuel pump prohibits running the bolt in from the front. The clam shells should be marked "L" for the drivers side and "R" for the passenger side.
Just my $.02
Here's my rusty .02. Those mounts with captive nuts don't work for our cars. You do have the correct mounts for our cars, saw the large "71" from the p/n & they are universal L or R, never had captive nuts. Now here might be the fix to make things work, it'll be a PIA but you'll get the extra movement on the frame side mounts. Just posted this idea in the Space City 1982 GP Build. Loosen the frame mounts but just enough to allow forced movement of them. This way you'll be able to give the mounts some play to work with. Had to do it to mine with the poly inserts. I have a bare frame so I had better access to do it that way. If the transmission is bolted to the block, loosen the mount on that for the extra movement. I never had issues like this with the earler style rubber on block side mounts.
