FYI, I have a set of mounts I got from O'reillys (same p/n) & the China man who made them has the inner rubber angled so I couldn't get the bolt thru, trying two sets of G body block side mounts. I even left the mounts loose & still a no go. I ended up using my Energy Suspension mounts after the dumb blonde finally read the installation instructions.
I had no issue with the Anchor brand.
At had this problem too, so I used a stepped drill bit and made the hole bigger.
No I meant the cross holes. The one the big main mount bolt goes through. I did that and manipulated the rubber portion of the mount around with a screwdriver until the bolt went on throughWhich hole(s)? My guess is on the two upper motor mount holes. That might work since the bottom cross member hole is already ovaled out. I'm going to see how these Duralast mounts do tonight before I resort to drilling
