Was the car ever hit?
Hi there...
I just read that your motor is bolted up now, so I may be a tad bit late on this....
Ran into the same thing m'self a while back and my fix was to head to scrappie's and yank a set of mounts from a TBI truck engine. There is some sort of spacer plate between the mount and the block that I didn't use for my swap. Don't have pictures... Maybe someone else does?
My 327 was in a Monte Carlo, then repowered with a 383. Was concerned about smooshing the 30 yo rubber out of the budget mounts I used on the first go round, so stuffed in some poly bushings and then discovered I had the same issues I.e. "mounting".
HTH,
R.
I'm glad some of my useless knowlage (wifes words) was help full.Success! With pagrunts advice and a little twist on my end, the block is mounted up!
Methodology:
Bolt the passenger mount loosely to the frame, thru bolt in the bracket and mount.
Driver mount not bolted to frame at all, thru bolt in the bracket and mount.
Drop some weight on the mounts to touch the frame but still have some give. I hooked the chain on the hoist to favor the passenger side a tad more.
Drop a little more weight
See that the driver side mount holes are nowhere close to lining up
Hammer the crap out of the driver side mount until the holes look somewhat close
Lift the motor a tad
Hammer
Drop the motor a tad
Hammer
Make sure the transmission tail is center
Hammer
Hammer again
Hammer again from a different angle
Check holes for alignment
Voila
Bolt up
Thank you all for your input, advice, information, tips etc. This forum is awesome. I'm stoked to bring this 383 beast to life!
Are you sure you are using the right holes in the crossmember? One bolt hole for the motor mount should hang off the front of the crossmember. It should look like this for SBC....View attachment 81173
