FINALLY, a progress update.
This is the first time in this project that I do some (reassembly) and shorten the to do list... Everything up until now has been making the to do list longer.
Not that I believe the to do list will not get any longer from now on... Im sure it will at some point!
I started work on the rear frame rail repair sections from Conrad, they're an excellent fit and saves a lot of time and frustration, my frame was so rusted I had to use all of the material provided by Conrad, which is great in a sense, but it was very accurately enough for my case, I did strengthen the lower half of the axle hoop while in the process because when grinding through I found that rust had thinned the metal severly mostly on the bottom of the frame rail, not so much on the sides or the top.
The mock up of the repair section just after cutting away the damaged metal
The pasenger side frame rail fully assembled
The welds are adequate, I lost patience with my grinder so cleaning wasn't professional, this will do the job on this repair, it's not a high performance kind of car in my mind
I have yet to fit the rear bumper brace to ensure proper fitment before finalizing the welds on the drivers side, but I'm confident I will get that done tomorrow.
Until then, cheers.
