Thought I would move the build over here from the 442 page. Here's what's been done so far.
Get the car home
Tear the front end off
Take the engine out
Take the body off the frame
Start to strip the frame
Sand blast the frame
The frame blasted clean
The frame coated
Install Inline Tube rear disc proportioning valve and stainless brake line
Come to grips with rear torque box body rot
Put the F**D 9 inch with rear disc together
Rebuild a Monte SS 12.7:1 Constant Ratio Gear Box
Show off the Dual Quad intake
Test fit the prototype 18 Billet SSIII wheel with silver vinyl inserts and red pin stripe
So that's where I am up till now.
Hutch
Those wheels looks very good, Where can I buy a set?Finally got a chance to do some more work to the old girl.
Stripped the cluster and trim out of the dash
Pulled the driver side door glass out
Pulled the rear glass trim and the rear valance panel (Holy Crap the flash shows the dirt)
Stripped the tail light wiring and trunk carpet. I found surface rust at both corners in the back of the trunk, but no sign of a leaky rear window??
That's all for now.
Hutch
