I had to peel the UMI Sticker off the Sway Bar (it was upside down). No worries though, with all the parts I got from UMI and all the free stickers they throw in, I have enough to cover the whole car! 😆
Hutch
Hutch
Looks great Hutch!
I've only got the one 18" proto wheel to check backspace with. 😛
Looking good! Balance and braking will be improved with those rims. I wonder about traction? That 455 is going to be a power house down low. How wide can you go in the rear?
BTW, the color combo on your car is my favorite for that year 442. Definitely worthy of the time and money you are putting into it. Thanks for sharing.
Thought I would move the build over here from the 442 page. Here's what's been done so far.
Get the car home
Tear the front end off
Take the engine out
Take the body off the frame
Start to strip the frame
Sand blast the frame
The frame blasted clean
The frame coated
Install Inline Tube rear disc proportioning valve and stainless brake line
Come to grips with rear torque box body rot
Put the F**D 9 inch with rear disc together
Rebuild a Monte SS 12.7:1 Constant Ratio Gear Box
Show off the Dual Quad intake
Test fit the prototype 18 Billet SSIII wheel with silver vinyl inserts and red pin stripe
So that's where I am up till now.
Hutch
where did you buy your proportion valve? working on 87 cutlass street strip car that some one installed rear disc brakes. also did all of your lines work on the new valve?
Beautiful work so far. Definitely a car to be proud of.
