Core Support some more:
Lastly, I smooth out the rough uneven edges to all the sandwiched together sheets of metal (pay no attention to my bird poop welding, I'm still a noob there)
Before:
After:
Just that little bit of metal removal made it look sooo much better.
Using a metal gauge I got with the welder, the sheet on the Core Support was too thick for the 24ga slot, but a little loose in the 22ga. I had a hard time with this. I was blowing through the metal like I was shooting 9mm at the range. The patch pieces were from a scrap sheet of 22ga and did fine, but the orig metal right next to it would blow through every 4th or 5th spot weld. I was very frustrated by the end, but I did get through it.
I did all the tricks with spacing my tacks and cooling the piece with an air nozzle, but nothing would keep the blow throughs from happening.
Thin metal and my lack of practice was a BAD combo
Hutch
