Something I was messing with in the middle of getting the tires.
I installed these bars on a cutlass I had before the 442. When the car went, I kept them. They're from a piece of 1" OD iron tube I bought from Home Depot. I cut it into sections, flattened the ends in the vise, and drilled 3/8 holes in them. Instant brace kit.
They're beat up and paint chipped from kicking around the floor under my work bench, but they'll clean up fine.
I made mine long enough that they sandwich the factory braces and adjoining attachment point everywhere but one spot.
First thing is jack up the car and place stands under the frame to eliminate body flex.
I drill and place my first bar in the passenger side, upper corner.
From there I can see where the lower center will fall.
I use and angle locator to make sure all the bars mount with the same angle to make sure they look uniform.
I eyeball where the top center hole should go and drill and mount.
From there, I had enough mounting points to drill and secure the rest. As stated before, all the points but one are at overlapping sheet metal areas in hopes of adding rigidity to the structure.
All done. **EDIT I cut the outside bars longer and put a bow in them at the center so they fit around the back bars they cross**
I'll probably just leave them in place until the day comes that I clean and detail the entire trunk.
Hutch
