Re: 1987 Olds Pro-touring project build *LONG*
Andrew the 87 looks good do you have any more pictures of it? If I lower a stock G body 2" there will be know more suspension travel thats not good? Andrew how much have you lowerd your car? I think I will only drop mine a inch then.How much do most drop there cars? I do not like driving cars with to much bumpsteer. I had friends with 510s that had no suspension travel, and they would change lanes on there own on roads that were poor, and could be a hand full and dangerous to drive. How much can you drop a g body before the handling turns bad. Does every one use drop spindle? So if you lower a g body and take out the suspension travel. Then run the new style of tires with out side wall, are you not adding to the problems of having little or no suspension travel? Whats a good set up for street strip car? In the past I did not care how bad the car would handle on the street, as I have gotten older I like my cars to go were I point them with out constant steering input
