CUTLASS 1987 olds turn signal help
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
I'm looking for a technical assist on turn signals for a 1987 old Cutlass supreme 442. This model has 2 turn signal indicators located on either side of the hood that face back towards the driver. Basically let's the driver know when a turn signal is on. Closer inspection show three wires going to each signal within each fender. I'm missing the wires for the left side. Where do I find parts for a replacement and how does it supposed to function? The other side has 1 tiny light that flashes when the turn signal is activated, but it appears to have 3 separate lights or just 1 light that isn't functioning to full capacity. Any help is appreciated.
Rktpwrd
Builder of Cool Shjt
4,168
23,918
Calgary, Alberta, Canada
As quoted from my Olds Cool build thread...
“Each indicator is split up into 3 sections, each section with its own color. White, blue, and amber. When the signal lights are activated, the amber section flashes, indicating the signal light is on. This also stays lit up when either the marker or headlights are turned on.
When you turn on the headlights, the white section lights up. When the high beams are activated, the blue section is illuminated. This is all done with fibre optics.”
Because this is done via fibre optics and not wires, if you’re missing the optic cables on one side you’ll have to locate replacement parts and reinstall them. To the best of my knowledge they’re not available new, so used will be your only option.
There are no bulbs inside the indicator housings, only coloured lenses. The optic cables transfer the lights up to the lenses where they shine through.
Hope this helps.
  • Winner
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Hope this helps.
Thanks. Makes more sense now. Wiring didn't look normal to me. Fiber optics sound like hard to find to me. Any ideas where to look? Thanks for the low-down.
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Here are a few pics of the fiber optic wiring and light assembly. One wire is larger than the other two and they all go to separate lights. Any assistance with finding some replacements would help. Thanks.
Rktpwrd
4,168
23,918
No problem, happy to help out.
Like I said earlier, new pieces aren’t available new so you’re going to have to locate used parts somewhere. I would check eBay, or maybe with fellow member 88HurstOlds. I recall him having a complete front set available recently.
Good luck.
