Besides the exhaust, a good tune up and make sure everything is working properly. You could also change gears out back. It wont add any power but you'll improve the acceleration.
psycobilly64 said:It's likely the olds is gonna be a long term project car (one I can drive as I fix it up). I'll probly have to get ahold of the parts I need a little at a time and build some things on the bench to be put in later.
olds307 and 403 said:That and 3.73 gears will help a lot. You will only run at 2000 rpm at 60 with stock tire height with 3.73 gears.
