To do the dual feed mod you will have to take the trans apart.
On the direct drum you have to remove the lip seal.
The middle ring on the center support. Pictured behind the direct drum. not a great pic but you can see I left off the middle seal out.
Here is a closer pic of the center support.
If you look at the middle here you will see two bolts. These hold the center support. the factory bolts have a hole through them. You will use the factory bolt on the left and you can use a Allen head bolt on the right side or tap the second bolt and use a screw or bolt. if you use s Allen bolt it is an m10 x 1.5 x 23.
If you do it this way you will need a billet or hardened forward drum.
