2004r to th400 what all is needed
NorthWestRider
301
70
just wondering what i will have to do to swap in a th400 into my 87 ss monte i know the mounting pad is suppose to be the same as 2004r so crossmember should stay same. But what all do i need as far as driveline. It looks like i hav the shorttail th400
Garrett1982
582
101
Uniontown, Pa
You will need a kickdown switch, a different converter if you don't already have one, and a a different driveshaft. The 400 with the short tailshaft is longer than the 200 4r even though the mounts are in the same location and it will need a larger slip yoke.
NorthWestRider
301
70
Converter i have now as far a driveshaft is the length the same or will this one need to be shortened or do i just need to do the 400 yoke
9,619
12,705
If you are changing to a 400 turbo trans over the 200R4 for the added strength then I would continue the process by ordering a stronger custom made driveshaft instead of spending money cutting, rewelding and balancing your old smaller diameter driveshaft.
NorthWestRider
301
70
I agree with you but right now i just wanna get it mobile for now
NorthWestRider
301
70
So today i went to wrecking yard and i found a th400 with the yoke so i pulled it. Both trans looked the same so i figured it would work so the one i pulled the yoke off of had a bolt threw the center and when i got home i looked at mine and it dont have that bolt hole can i still use this yoke or did i grab the wrong one?
NorthWestRider
301
70
Does this look ok or do i need to find a different yoke? My trans dont have the threads in the output shat like the one i pulled the yoke off of
