2004R
Reactions: Street Sweeper22
The 1/8npt port is on the driver side just above the shift shaft. As long as you don’t have dual exhaust, then it’s easy as pie to get to.
I’m 110% in agreement that the TV cable must correct geometry at the carb and generate correct line pressures at the correct times.
Non stock built transmissions will make ALOT of line pressure in reverse, 1st and at WOT.
Lastly, you do not adjust shift timing or firmness with the TV cable.
I believe that 8.5 out of a t-type should have 3.42 gears in it. I could be wrong so if anyone knows better please chime in.
From Olds parts illustrated.
8.5"
1988
No 8.5 available
85-87
RPO GU6 3.42 avail as a posi with an added RPO code.
RPO GT4 3.73, avail as a posi with an added RPO code, no posi avail in 1987
84
RPO GT4 3.73 only
83 back no 8.5 available.
LIkely you will need a search engine to track it down but I did recently post a brief how to on dealing with the TV cable. Getting the cable tension just exactly right is the hardest part and can take more than one try but it can be done. Locating the correct cable mounting bracket can also be something of a headache but they too can be scored if you are will to wander through fields of hulks and do some exploring.
The lock up provision comes as a default ability in factory 200 R4's and 700R4's. The electrical plug in found on the side of t-case is not to actuate it, it is actually to de-actuate it during braking. The lock up automatically resets itself when you accelerate again. There are pictures floating around that I took of what/where the factory switch for the lockup looks like/can be found.
As for there being no non lock up versions of the 700R4, we-ell, the factory didn't as far as I know but, if you go aftermarket then TCI offers a non-lockup version of the 700R4 under their part number TCI1060. They have it listed in the 2022 catalogue on page 143.
Hey thanks for the info.
Just reading through this so already lots of good information.
Edelbrock and Holley makes the geometry correction connector needed. Summit, Jegs and some others sell it.
On the TV it basically needs 100% at 90% of throttle. Length wise it is a direct replacement some modification to cross member might be needed.
Reactions: Longroof79
I used the factory TH2004R TV bracket with a Dualjet on an Olds 260. I thought it would work, it didn't. Suprised considering it was probably in front of a TH200 which also would have used a TV cable. I drove around the block, super sloppy shifts. I added zip ties to the cable to add tension and all was good. Either the TV geometry correction and or a universal TV cable, where you set the length may be needed to work properly. Were there any factory Dualjet and 2004R factory combinations? None that I can think of.
The major downside to the Transmissions that need TV cable, if not hooked up correctly, trans can burn up as little as 30 miles.
Too many still see the TV as a "kick down" cable and it is not. As long as you start the project knowing this, you are world's ahead. The 700R and 2004R respond well with 2300 stall, provided your engine is setup for that.
If you are running stock cam, compression, manifolds and exhaust, ... You are better off with stock converter. However if you plan to improve engine and exhaust at later date the 2300 stall won't hurt.
Lockup can run stand alone. You just need the kit or just hard wire but make sure to add a disconnection at the brake pedal or switch.
Too many still see the TV as a kick down cable and it is not. As long as you start the project knowing this you a world's ahead. The 700R and 2004R respond well with 2300 stall, provided your engine is setup for that.
I really like the launch from my PATC 2200 to 2500 stall, it flashes at 2350 rpm. The factory common D9 stall around 1900, a 300 rpm gain from his TH250C converter, plenty for a stock 3.8.
I have a question and concern pertaining to putting a 200-4R in my wagon. The engine is a mild SBC 350, stock convertor, running a Q-jet carb. I'm guessing that the Q-jet won't need any type of TV geometry correction arm, even though my '79 wagon never came with a 200-4R stock. I was planning on using the throttle/ TV bracket from a 200-4R equipped V-8 Oldsmobile. Any feedback as to what TV/ throttle bracket is best on a SBC?
Perhaps the throttle bracket from my original 305/ TH 200 would be more suitable? Although I no longer have that bracket.
