2nd gen fbody steering box
autonaut
209
31
will it work on a gbody?
Has pitman arm too.
12,177
9,796
If I'm not mistaken, you'll have to replace the pitman arm to a G-body part. I believe the length and offset are different. Perhaps one of our fellow members will confirm that.
What type steering box is in your car presently?
Speedy94c
Sep 3, 2016
58
25
I have used them on several cars and not changed the pitman arm. They are the same as the G body. Quickens the steering by one whole turn.
You will like this upgrade.
UNGN
3,048
3,267
Southlake, TX
A 3rd gen F-body Iroc/Trans Am Box would be better than a generic 2nd gen box, because it would be high effort and guaranteed to be 12.7 ratio.
A lot of 2nd gen F-body boxes were floaty crap. You had to get a Z28 or WS6 box to get a good one. The stock box in a MCSS, GN, TType or other performance G body is better than 80-90% of 2nd gen F-body boxes.
If the Box is out of a WS6 or Z28, $110 USD is a good deal. if its out of Straight 6 1976 Camaro, pass.
autonaut
209
31
I have the 605:(
20,399
The G body pitman arm is not the same length and is not designed the same as the F body pitman arm...
autonaut
209
31
Well, i have one for a 3rd gen base firebird but without the pitman arm.. could i swap that over from the second gen?
I eill msot likely be running wide c4 swablade rims so decreased turning radius might not be a bad thing!
7,989
18,702
7,989
18,702
12,177
9,796
I have the 605:(
I could understand why you chose to replace that oversize paperweight...or small boat anchor.
For one, they're leakers. I've replaced two of those in my car over the years until I went with the 800 series Monte Carlo SS unit, which is beefier and will outlast the 605.
