305 700r Swap
LilSpann601 said:
Can someone tell me which year 700rs are computer controlled so I can avoid them ... ?
I think every 700r4 is computer controlled. All you have to do is add a torque converter lock kit.
It will most likely have a lock up converter. You can get a lock up switch or buy a non lock up converter. Also 300hp from a cam in a 305, no way. Your gonna need heads, intake, carb, headers. The reason people say build a 350 is because if you did the same to a 350 as they did to a 305 you would have much more power. If you are going to do a full rebuild anyway then I would buy a core 350 for a 100 or 200 bucks and rebuild that, everything else will cost the same. Goodluck
They will all work without a computer. You just need a lock up switch.
93 could be a 4l60e. Not sure. If it is then you would need a whole computer. Does it have TV cable?
