LilSpann601 said:Thanks JBreu you were right on the money.Thnks again
d
Can yall tell me how can i make a brake booster line or can i buy an after market line that screws to the back of my carb
You can use one of the prots on your intake manifold......grab a 90 degree fitting and clamp your hose to that..Or check the carb, there may be a port on the rear of the carb that was blocked off..Hope this helps.....As far as the TV Cable bracket and throttle bracket check out Jegs, that's where I got mine from.... 8)
