Just wondering why you would buy a 800 cfm stage 2 Quadrajet for a 307. What modifications have you done to the engine?
I looked at the wrong one when I sent that earlier. I have the stage 1.Just wondering why you would buy a 800 cfm stage 2 Quadrajet for a 307. What modifications have you done to the engine?
Thanks for the info. I couldn’t find any information on a non computer controlled 307 which is why I posted the question. It’s not the first time I’ve been completely wrong and I’m sure won’t be the last time.X2 on manifold vacuum. You are completely wrong on the 307, Canadian cars were non CCC til 86. I owned one and worked on quite a few. I saw anywhere from 13 at 1100 to 22 at 1100 for timing specs. The one with 13 at 1100 honestly ran the shittiest. My car had 16 at 1100, 22 lost fuel economy, I think it ran best at 17 or 18. But remember it would have a 30 degree vacuum can, that is a ton of part throttle timing. The mechanical curves were no doubt different amongst them. The carbs were calibrated ridiculously lean, just freeing up the exhaust and removing the EGR made it stumble and backfire at part throttle. The only 307 have made ping was when I put very lean secondary rods in a Qjet, sounded like marbles were being thrown in when the secondaries opened.
We are all wrong sometimes, my wife does say I can put it on the calendar when I am right. It doesn't happen often but does every now and then. I almost forgot I had seen so many different timing specs on non CCC 307's. I wish I would have recorded the Jets, rods and hangers in those 307 carbs I rebuilt, info that just isn't out there. One thing that didn't exist was a non CCC 307 HO motor. The Cutlass line was all sbc powered up here except the Hurst/Olds, 442 and 88 Cutlass Supreme Classic. They were all CCC 307 powered and were American cars with minor changes like Metric speedometer's. The non CCC 307's were in Delta 88/98, Buick LeSabre and maybe chebby Caprice's.Thanks for the info. I couldn’t find any information on a non computer controlled 307 which is why I posted the question. It’s not the first time I’ve been completely wrong and I’m sure won’t be the last time.
Sounds like your wife and mine use the same book lol.We are all wrong sometimes, my wife does say I can put it on the calendar when I am right. It doesn't happen often but does every now and then. I almost forgot I had seen so many different timing specs on non CCC 307's. I wish I would have recorded the Jets, rods and hangers in those 307 carbs I rebuilt, info that just isn't out there. One thing that didn't exist was a non CCC 307 HO motor. The Cutlass line was all sbc powered up here except the Hurst/Olds, 442 and 88 Cutlass Supreme Classic. They were all CCC 307 powered and were American cars with minor changes like Metric speedometer's. The non CCC 307's were in Delta 88/98, Buick LeSabre and maybe chebby Caprice's.
