307 to 403 Olds swap...info please?
Subscribed.
Can't wait to see how this turns out.
Very nice!! This is exactly what I'm planning on doin with my 84, if I can find a motor around here. 🙁.
Also couldn't help but notice the pontiac in the garage. 😉
Couple of update pics from the shop. Have not been able to get down there much lately, but 307 is about ready to come out. Still will have to paint then engine bay, and then will drop the 350 in.
-Mike
Ok the guilt trip from friends is wearing me down. I've been talking to some Olds folks and am told VHT #sp-132 Universal Gold works well. Not perfectly correct, but less metallic than the Dupli-Color gold AutoZone sells.
About $8 a can. What do you think? Do I need to pull the intake and valve covers off and re-paint the block....?
Nothing like pressure from friends....
Here's the only two pics I can find of it on someone's cars
This is what I had purchased at Autozone...it looked VERY wrong!
-Mike
Looks great!!
Aren't you supposed to run that alternator belt down past the crank pulley too? Just wondering.
It is a beautiful setup!
nope thats how i have mine on my olds 350
Sorry for not updating!
The Cutlass is still in pieces. I could not find a dipstick tube for it, so ended up taking the oil pan off the old 307 and beating the tube out of it from the bottom. Man what a MESS, that 307 was NASTY inside. I kept the oil changed the year I had it, but the bottom of the pan was full of chunky sludge. It’s no wonder the car had no oil pressure if it was sucking that into the engine. Yuck.
I had to take the passenger side exhaust manifold off the 307 to get the dipstick tube out as well, the tube runs under it, between the manifold and the block. It’s amazing how small the 307 exhaust ports are, they are round, and about the size of a quarter. It’s no wonder those engines are so weak, they can’t breathe! The ports on the 350 are HUGE in comparison.
Also had a little issue with belt alignment. The 350 harmonic balancer is just a tad wider than the 307, so I have to put one washer on each of the water pump studs to align the upper and lower pulleys.
The current issue is sorting out the vacuum stuff. I’m not running a smog pump on the 307, and have removed all the emissions-related garbage, but still have the EGR, have to make the carb and cruise control work.
The carb, distributor, and overdrive in the transmission are all controlled by the computer….and I don’t know how the computer is going to react to the having the majority of the emissions devices removed. I really hope the car runs and shifts!
I’m thinking if it doesn’t run, or runs terrible, I may have to get an aftermarket carb, a pre-1980 vacuum distributor, and an aftermarket switching device for the overdrive, and just totally take the stock computer out of the mix. I guess we’ll see soon enough! Getting close to turning the key!
It is cool to finally SEE the engine in the car! Will keep you folks updated.
-Mike
