I fully admit to being a little over my head on this project. Advice is funny, it was either use all the stock stuff, it'll be fine, or get rid of all the stock parts and use a 1406 Edelbrock.
It was a pain putting all the stock sensors, hoses and stuff back on, plus I rebuilt a second quadrajet, because I was told my first one was too far gone. After all that work, I just could not seem to make it run right...so now I went to Plan B.
Here is the latest update:
I was told that Spectre adaptor/spacer I bought yesterday is way too restrictive, and I should return it, and put a flat adaptor plate (EDL #2732) on the intake, and use a normal 4-hole square-bore spacer to raise the carb over the EGR boss.
So sometime today I'll make the rounds to the parts stores again and do that.
Also have to buy an additional mount, TCI-376710, for the throttle and TV cable connections on the carb, and I may have to buy a universal bracket kit that the throttle and TV cables run through, either an EDL-8036 or a Spectre #24283. BUT some have said the stock 200R4 Cutlass bracket will be fine. We'll see.
Lastly I have to buy a banjo fitting for the fuel line, part # EDL-8089, so I can retain the stock air cleaner assembly, which I want to do.
I know other may do this Olds 307 to Olds 350 or 403 swap, which is why I'm trying to document all this.
Plus, I appreciate the tips and motivation from everyone.
-Mike
-Mike
