307 to 403 OLDS
bracketchev1221
1,421
1,664
Just a cruiser!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Yeah I am still hoping to find an 8.5" rear for my "cruiser". Even though there is nothing wrong with the 7.5 for "cruising"
8,827
7,783
The stock spider gears tend to explode just horsing around....
spidereyes455
788
1,645
Northeastern PA
When I was going to build the 403 in my 80 I had planned on using a set of early 350 heads 5, 6, or 7 using the 403 sized intake valve. As well as this cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1180&sb=0 . Add in a good 200-4r with a D5 converter headers with a good exhaust and an 8.5 with 3.42 or 3.73's should get a "cruiser" that'll pull at least 13's on street tires all day long.
JAMCAR223
1,853
5,507
Houston, TX.
That's what I'll be doing. 403 with #5 350 heads to bump compression into the mid 9's. I'll use the 403 intake valve, deck the heads .020-.030 to compensate for the thicker head gaskets that are available today, a smaller Edelbrock Performer Plus cam, Edelbrock Performer RPM intake, 750cfm carb, Thornton shorty headers, true 2.5" duals, 455 BBO oil pan, serpentine conversion. I have TH-350 automatic, and T10 4 speed manual transmissions to choose from. I'll be using the original 7.5" rear axle with a F Body Torsen unit, rear girdle w/ main cap supports, and a 3.08 gear. Cruiser... If it runs 13's, cool...
8,827
7,783
Do you have 93 available? You will need it will 9.5 to 1 and that cam. I ran 9.6 to 1 with that cam in my 350. It liked to ping even on 91. I retarded the part throttle timing around town and ran very cold NGK 5670-8 spark plugs, felt meh driving around town but ran equal to mid 14's in the 1/8, a 9.4 with more in it with a 2300 stall, 2004R, 3.42's in my 3750 pound 1988 Cutlass Supreme Classic. I would seriously aim for 9 to 1, the cam will act even smaller with 53 more ci. It will make driveability nicer as you can add much more part throttle timing, it makes an Olds V8 feel crisper.
shanghaismith
230
32
Macon, GA
Here are some specs and pics of my 85 Salon with a built 403. Oh yea, it's for sale. This car ran mid 12's
The engine is an Olds 403 .040 over with:
Arias Pistons
330 Steel Crank
J&S 4 Main Girdle
Old Performance Products Oil Pump
Midon 7qt oil pan
Lunati VooDoo cam and lifters
Comp Cams roller tip rockers and rod guides
RPM Performer Intake
#8 Ported Olds heads
SMI Quadrajet
Hedman Elite Headers
Be Cool Radiator and Fans
200 4R Transmission:
CK Performance shift recalibration kit.
10 Vane Pump
Sonex Servo
GM 2004R 12" LOCK UP STREET STRIP CONVERTER HIGH STALL
Hardend sun shell and stator tube.
Eagle Steels and Clutches has 1 Extra clutch and steel
118105
118106
118107
Reactions: 9 users
Clutch
5,189
10,913
Brick NJ
Do you really need to go 60-70-80, I mean your state speed limit is still 55:banana:
Here in the Northeast speed limits are a suggestion. At certain times of day if you're not doing 85 on the parkway you will get run over.
ItsnotaGN
662
1,142
Colorado
Oh yeah, that was just sarcasm. The LIE was always the same way. If you weren't doing 80-85 in the left lane, someone will flip you off, cut you off, and brake check you hoping you lose control, flip over, catch fire and die because you aren't going fast enough. That or when the light turns red for cross traffic if you aren't moving as the light turns green, 15 cars behind you will be laying on their horns and cursing you out.
19,992
Thats me!!!!!!!!!
