355 intake choice ?
It sucks they're making you have the emissions stuff when it is 20+ years old.
In my state when it's over 20 you do what you want.
I would stick with the holley ebby weiand or even summit brand which if unbadged weiand intakes. But stay away from professional products intakes. I had the crosswind which is the airgap knock off the ports was not even and the wall between the intake a exhaust ports would be uneven from port to port which caused a vacumm leak. I replace intake gaskets 3 time with no luck then i bout the weiand stealth highrise problem solve. Good luck on your intake choice.
He can rebuild any quadrajet but one thing he does is to make sure the carb is a good candidate to rebuild so he can tweak it so if you want to use it one a larger engine in the future the carb can be used. I know he had 3 built and on the shelf last time I was speaking with him so one of them might fit your package with a few tweaks. I will contact him and see what those carbs are like and let you know. One of my sons live in Toronto and I make it there quite often. I'm heading there this weekend to do a tune up on his Ford....I pray the GM Gods don't hit me with lightening...lol
