patmckinneyracing said:
I've enjoyed reading this post. I'm remember being at the exact same point where your at with your car except I was 14 at the time. I'm 19 now (just wait till these older guys jump in :wink: ) and this site will definately help you out in the long run. On top of my old man teaching me for years now, you will learn things on your own and figure out different ways of going about certain aspects of the car. I daily drove my malibu for 5-6 years before the driveshaft snapped (dont ask me how).
As for the engine, if your building this car to handle primarily on the street, then keep your torque numbers in mind. The rpm air gap intake will help you with that. Do not go with a single plane intake as that is meant for the high rpms and drag racing, which you will never see. Remember the cardinal rule "bigger is not always better". There was a point where I wanted to put the biggest cam, port/polish the heads, and be the fastest car on the road. Then as you drive around for a while, you realize that there are gonna be cars faster than you. My rule is whenever I build a motor, I use forged internals as a safety precaution and to avoid the possibility of an internal cast part failing. I run flat top hyper pistons in my 350 and haven't had one problem with them.
I know your figure of speech when it comes to the mustangs as I've seen every variation of the damn things, including those with cowl hoods, and am tired of their bark. But the simple thing you need to realize is that those mustangs are a dime a dozen and your car is not. Those guys can easily go to a used car lot and find another one. That's why I stopped kickin every import and tuners a** that I came across because it is not worth it, especially after you invest 6 years worth of time, money, and labor.
Somebody taught you well and you did some good listening! BTW...is 50 years old, old enough?
Yeah, I used to have a 69 Camaro that had a nice lopey cam...it sounded real mean. After many years you start to learn...and I did too. Sounding mean don't get it done in a street car. Torque does! You feel torque. Horsepower is just a mathmatical measurement and an engine is considered a horsepower motor when the powerband is in the higher rpm ranges. All engines make more hp over 5252 rpm due to the formula used to compute horsepower. Optimize your power range for 7000 rpm and you have a horsepower motor. Optimize it for power in the 4000 - 4500 rpm range and you have a torque motor (torque MONSTER!). Does your street motor live in these rpm ranges? Not generally.
Keep your duration in the 220 - 230 range with a lobe seperation of 110 - 112 and it'll make good torque. You can also use streetable gear to keep your engine in that powerband. Push the duration into the 240 - 250 range with a 106 - 110 seperation and it will lope like hell! It will also be a flat out dog on the street unless you run 4.56 gears to keep it in that rpm range. And don't fool yourself into thinking you can run 4.56's unless you have an overdrive transmission. If you don't, don't plan on leaving town or stray too far from your local gas station. 5000 rpm at 60 mph isn't *streetable*.
I'm not saying a torque motor doesn't have a lope to it...just a lot less due to smaller duration and less overlap on the cam. It makes guys with that bad-*ss sounding cam wonder how you just blew their doors off with such a *stock* car...
One word...Torque!
You feel torque...you measure horsepower.
