CHEVY 383 stroker build
xylorex
305
395
New Orleans, LA
I built my engine because I had never done it before and wanted to learn. I like learning how to do stuff. I can't quite afford the lathes and milling machines they have at a machine shop, but I was able to swing everything else... The cylinder heads and fuel injection setup were purchased used and helped some with the final price.
Marketmerlin
I'm about the same way but I have built about 5 in the last 25ish years. I'm by no means an expert builder but want to put a little bit of my knowledge to work. My current build is a 385 I'm looking to get around 450 on 87 octane. I haven't seen a crate like that. I also have a 305 in a part's car I'd like to de-stroke to a 267 as a fuel saver project. I think it would be hilarious to slap some 267ss badges on the fenders of the old el camino.
mclellan83
4,302
9,587
Pgh, PA
Going to be going down this route myself, my buddy helping me with everything really enjoys the building process so I know thats why he is focused on the building part of it. But so far I don't think I will be close to the 7k mark but we all know how it snowballs. Looking at doing a Scat rotating assembly after first thinking I was going to go PBM, AFR heads, and Comp Cam XR282HR.
scoti
1,986
3,423
Texas
Curious of the details/internals/parts that yield ~450hp on the cheap stuff w/o issues.
Marketmerlin
I honestly don't know what the hp and tq will be. It started as an abandoned un-assembled short block from a local shop. I believe it has eagle 5.7 rods and crank but pistons didn't work for what I wanted so I got a set of thin ring SRP-139629-8 16cc dished pistons.
Heads are the budget afr 195 enforcer's that I blended and polished the chambers and just knocked the rough casting out of the runners with 80 grit. The shop is doing a 5 angle on them. Block is just a 2 bolt 2 piece .040 over 350 getting zero decked. Once the heads are back I'll cc the chambers and know what my compression is going to be exactly. I know it's somewhere between 9.2 and 9.6 compression.
Cam is the lunati voodoo roller 20120711 219/227 @50, .549/.565 lift with the 1.6 rockers. Elderbrock performer spread bore intake and rocking a quadrajet. I sat the heads and everything on it a couple weeks ago to see how it's going to look. Lol I'm getting anxious to say the least
scoti
1,986
3,423
Texas
Does sound like a stout little combo. I'm betting it will be on the higher end of that comp range 'guesstimation'.
Zero deck,16cc dish, & a 3.75 stroke w/the likely small 64cc-ish chamber.... it should have some pep since the cam is mild.
Marketmerlin
I'm not so sure. They advertise them at 64 and 65cc depending on the site you look at but real world test have shown 66.5cc out of the box. That's not counting I grinded 1 or 2cc out of the chambers blending the seat to chamber area. Out of the box there is a sharp ridge all the way around the seat about .020 tall or better at the bottom red line. That's not even counting the mound just outside of that. You can kinda see the shadow of the mound between the red lines. 2nd pic isn't done but a little closer to finished.
scoti
1,986
3,423
Texas
Gotcha. Def will depend on any material removed if they're not resurfaced after the effort. Post up what your final measurement yields.
