Yes this is one of his engines and they’re good it’s just customer service , there was none.
Sounds like an understatementYes this is one of his engines and they’re good it’s just customer service , there was none.
Did you check the spring pressure to make sure they were within spec for your cam?I put a set of heads on a 355 last summer and spent the whole summer adjusting the valves every week or two.
Roller rockers are not the cause of the clatter. Are you running a hydraulic or solid cam? I'm going to start with valve adjustment.
Will check all of the above. Never checked springs before, but can I go back to the old style rockers with my set up. And I also want to switch to th350 trans. Should I get the lock up or the non. I really thank every for help. Sorry for delay, bomb did a number on serviceI put some Ford/Crane Cobra roller rockers on a GT40P top end 5.0 HO with stock HO cam. As soon as I went to the roller rockers I got valvetrain noise. I played with the geometry a bit, preload, and pushrod length and eventually just lived with the noise. Fast forward to the 1500 in my sig, super mild Ramjet cam in a 350 Vortec. I added Comp Pro Magnum chromoly roller rockers and they're much quieter. I can still hear a tiny bit of noise with the engine running hood up, but I have to be looking for it. Can't hear a thing inside the truck. My Z06 is a little noisy too all stock inside, but that's normal.
Are the Comp Cams rockers arms a full roller or just a roller tipped steel arm?, regardless going backwards to install a stock rocker is not the way to go as stated it sounds like an adjustment issue. I also doubt there is any issue with spring pressure.Will check all of the above. Never checked springs before, but can I go back to the old style rockers with my set up
IMO since your engine is running I would do a hot lash final adjustment while running and it is even easier if you have
I’m about to do and I’ll send a pic and you can see.Are the Comp Cams rockers arms a full roller or just a roller tipped steel arm?, regardless going backwards to install a stock rocker is not the way to go as stated it sounds like an adjustment issue. I also doubt there is any issue with spring pressure.
IMO since your engine is running I would do a hot lash final adjustment while running and it is even easier if you have a full roller rocker.
