383 stroker rocker arms
If these are Comp steel roller tip rocker arms and I see you are running aluminum valve covers, they maybe noisy, no matter the adjustment. Mine were properly adjusted, just sounded like a sewing machine under my aluminum valve covers. I switched to Scorpion aluminum roller rockers and they were much quieter. Think of clattering inside a tin can. Again, not a tick, more like a sewing machine.
Reactions: fleming442
If you don’t do something soon and report back some results your help is going to lose interest. Sorry to sound harsh but turning an hour job into a two week conversation is a bit hard to justify.
OK I’ll get all my ducks in a row before I have any other discussion I am going on 60 it’s even hard for me to figure out how to work this site. Do you have a very good valid point and I apologize
Reactions: 1320John$$$
Here is the pic. So do these naturally make noise and maybe I should get different ones
Those are full rollers and should work fine for your engine.
As stated the valve covers can make a difference in suppressing valvetrain noise if you don't have them a thicker cast aluminum valve cover will help but by design the roller rockers will make some noise and I would still do a proper lash re-adjustment first.
Having a roller fulcrum and roller tip frees up a lot of friction and is definitely something you want to have, I do find the Comp Pro Magnums I run on my 355 SBC are typically tighter and quieter than a comparable aluminum rocker (but more expensive) and I run Comp stainless rollers on my current big block.
Just turned 72, got a couple on ya. I run a solid cam that has .022 lash and they are still quiet
