Doing a hydraulic clutch setup on my cutty, all i need now is pedals. What is easier to modify to fit, 3rd or 4th gen fbody pedals? Looked into the johnB pedal but it seems a little steep, anyone know if it will bolt to my g-body brake pedal?
CostasCutlass said:I'm in the process of putting in a t5 with hyro linkage and pedals, all out of a third gen Camaro. From everything I've read I should be able to use the the bracket from the brake pedal and just have that welded onto the f-body pedal assembally. I'll be doing a build thread once everything is in and running, so I'll let you know how it works out.
Also, check this out: http://ls1tech.com/forums/manual-transm ... iteup.html
It shows how to make the master cylinder adjustable instead of having to just extend it. Make sure to read through all of the pages before attempting it, a couple guys learned the hard way that u can only thread down so far before the rod becomes hollow. Also, you should be able to skip taking the master apart, that would only be if the linkage came out too far. But in the g-bodies the rod is always too short, this way you can adjust it to where it feels perfect for you, and if you cant weld its even better lol. Well hope that helped somewhat, good luck with everything.
CostasCutlass said:It shows how to make the master cylinder adjustable instead of having to just extend it. Make sure to read through all of the pages before attempting it, a couple guys learned the hard way that u can only thread down so far before the rod becomes hollow. Also, you should be able to skip taking the master apart, that would only be if the linkage came out too far. But in the g-bodies the rod is always too short, this way you can adjust it to where it feels perfect for you, and if you cant weld its even better lol. Well hope that helped somewhat, good luck with everything.
pontiacgp said:I tried to use the f body bracket and pedals but the the angles of the bracket are not even close to the G body bracket and the pedals were too high and too close due to the pedals design even mounted on the G body bracket. If you have the chance place the two brackets on the floor using the floor as the firewall and you'll see the difference of the brackets.
Escaped_Psyco said:CostasCutlass said:It shows how to make the master cylinder adjustable instead of having to just extend it. Make sure to read through all of the pages before attempting it, a couple guys learned the hard way that u can only thread down so far before the rod becomes hollow. Also, you should be able to skip taking the master apart, that would only be if the linkage came out too far. But in the g-bodies the rod is always too short, this way you can adjust it to where it feels perfect for you, and if you cant weld its even better lol. Well hope that helped somewhat, good luck with everything.
Can't I just make a stop for the pedal? I only need an inch of travel for my hydraulic throwout bearing... Unless I'm totally missing something...
