86Cutlass383SR said:1983ss454 I'm curious which hyd t.o. bearing you're using. I've got a 3rd gen master and may try a differant route with mine later in the future.
I have the modded 3rd gen pedals in mine. I tried the 3rd gen master and slave and stock 3rd gen hyd bell and couldn't keep the clutch from slipping. Bought a new master/slave pre-bled and the problem was about the same. I was making decent money at the time so I bought a Lakewood bell for the 83 f-body and converted it all to mechanical. That worked great.
I'm now moving up to an 11" clutch and pressure plate and, depending on pedal press and such, may look into converting back to hydraulics later.
I thought about going with the McLeod master which looks like an aftermarket aluminum version of the stock plastic master. But, I couldn't get any idea which hyd t.o. bearing I needed to match up with it as far as stroke length, master diameter, and such.
