Haven't updated in a whilw so here goes....
We found an olds 355 and picked it up for $100. The rotating assembly is brand new (rebuilt), but other than that its a bare block. So I've been gathering parts for a while now. water pump, intake, flywheel, gaskets, rockers, pushrods, pulleys, brackets, fan, bolts, timing chain, timing chain cover, engine paint, harmonic balancer, motor mounts :shock: you get the idea :lol: . Right now I just need a carbuerator, distributor, frame mounts and other misc. small stuff.
I have a dist. located at the junkyard but it didn't want to come out, I'll try soaking it with penrtrating oil or gas.
I found a '77 olds with a 260, non A/C, I'm using pulleys and brackets from that. Obviously I'm not going to run A/C. Theres a regal at the junkyard with a nice heater box, I'll use that. I just have to figure out how to remove the dash and get all the ducts.
I also found a double hump crossmember at the junkyard, with the g-body cars, but not in one. I'll have to compare it with my car to see if it has the right transmission mount and will bolt up.
When this is all said and done, I will be running a '73-'74 oldsmobile 355, no computer controlled stuff, no A/C, headers, and true dual exhaust.
