4 Speed conv. w/Hyd. Clutch
What pedal setup are you using? it would be awesome if you could provide some pictures and a part number for your FBody parts. Thanks!!!!
I am using the G body housing and brake pedal, I cut the foot to match a stick car...I used the F body hanger bolt and the F body nylon bushings along with the F body clutch pedal. I lenghtened the F body pedal 3/4" and adjusted the angle of the pedal so it would sit slightly closer than braked pedal so I could slide my foot behind it to rest on highway drives. I removed the G body parking brake pedal and cables and installed the 3rd gen F body emergency brake set up.
Reactions: fleming442
Lots of good info here: http://sickspeedmonte.com
Bernie Duplan (the guy who owns the Monte Carlo and runs that website) is a good guy. He was very helpful answering my questions and knows his stuff.
one other part I would get is the clip for the clutch pedal pin that they used on an A body ...the nylon retainer you get with the F body master is difficult to remove and the teeth usually break removing it.
I used Bernies st up, cost a bit more but works awesome, I did us the 3/4" master, but If I was to do it again I would go 7/8" master and work with the adjustment so it wont extend the slave to far,
