And, to the OP, I am not ragging you man nor do I know how old you are? I look at these threads as a general discussion of the issue. That said, younger folks like I was once, do have a passion for headers that you tend to learn the hard way are often completely unfounded. Does it got headers on it? Yeah, I have been there. I put a set of headers on an otherwise stock 327 back in the mid-70s which did nothing and then put a big lopey camshaft in it when I was running an old Carter AFB tiny 4 barrel [like 400cfm if I recall??] again with stock 1.76 tiny valve heads. But, of course, I could open the headers and people could hear that big lopey cam, and the thing "sounded" badass . . . ran like $hit. Finally, since I did manage to build the low end of that small block well, I got a set of 2.02 heads [1.94s probably would have been sufficient] and a 650 Holley with a Performer intake and boy did that change things. But, again, like from 3500-6500 rpm.
That big block with W/Zs will start pulling hard at only 1500rpm and you are effectively done by 5000rpm, less than that if it is a stock smog motor. My big block has mildly ported Edelbrock aluminum heads just to even out the inside and outside flow numbers in case I ever want to move to FI and headers [probably won't happen] but, with 750cfm on top, Performer intake, the W/Zs, and a .496/.512 224/234 cam, I shift at about 5200 where my HP really starts to fall off. So, for an all out race condition, I am limited. For a street rod, to date from a rolling start because those 15" BFGs won't begin to hook up, with all of that torque, this thing is so snappy quick [a well tuned CCC carb feels a lot like an FI car], I walk on just about everything up to a speed that is safe for street rodding where the HP limitation starts to become problematic. I am anxious to see what the ole girl will do lowered with a much improved suspension, brakes, hardened rear end internals, 1350 joint drive shaft, frame reinforcement, and 275/40/18 high performance tires out back both out of the hole and around auto-x and a few road course twisties just for fun? FWIW, I don't exactly intend to dominate the GTV circuit . . . just out to have some fun and show what even a G-body can do?
Anyway, I am just wanting others to learn from my mistakes and those I've seen others make in my nearly 60 years. That is all I am trying to do here.
