The Performer manifold is better for a street build, it fits both square and spreadbore carbs and is taller than stock but shorter than the square bore Edelbrock RPM airgap. My 350's coated Sanderson's don't put out much heat at all, require no gaskets between the heads and manifolds and aluminum collector gaskets work really well, lasted years. In a 455's case, run the Thornton W/Z manifolds with the larger openings and 2.25" or 2.5" dual exhaust, simple and fits.
