And now some shots of the new motor I'm building. It's a 421" SBC built on a Dart Little M block.
The block after I painted it:
To handle the power, I ordered it with the billet steel maincaps:
The 4340 crank is forged in the U.S. (Kentucky) for finishing at Howards Cams. I like my stuff bulletproof, so I got the big block snout for extra beefiness to handle the blower drive:
So far, all the measurements on the block, crank and timing gear have been well within spec:
Howards Cams forged billet rods with L19 capscrews:
I had JE make me some custom blower pistons to get the compression ratio I want (9.2:1). They are ceramic coated on top and have the TuffSkirt coating on the barrels:
To handle the airflow, I went with the new AFR 235cc Eliminators. JE had the chamber pattern for these heads and cut the piston dishes to be an exact match:
Shot of the intake port CNC work:
Fully ported Motown single plane that I modifed for EFI. Also cut up a nitrous plate and turned it into a spraybar and embedded it into the manifold. Since I want to keep the stock, flat hood I couldn't afford the stack height of the plate:
Closeup of the porting and spraybar. The spraybar here is only laying there - it needs to be epoxied in place then I'll do a light skim cut across the top of the manifold to make it flush:
And finally the new blower. I'm replacing the current Vortech V-2 T-trim with this V-7 YSi:
I'll be running a Comp solid roller on this motor as well. I picked different intake and exhaust lobes from their catalog. With the 1.7 intake ratio on the T&D shaft rockers, and a 1.8 exhasut ratio, the specs are: 250/[email protected]", net lift .697"Int/.702"Exh, 115LSA. Springs are 700# Pacalloy. After accounting for lash and the rocker ratios, this cam should act like a 244/[email protected]" hydraulic roller but rev safely to 7200rpm.
I'll be running 18-20# of boost with E85. My conservative expectation is 900rwhp without nitrous.
More to come. I'm off to work on fitting the oil pump shaft.
Jim
Jim
