I am looking for a little advice here. My motor mounts didn't line up with the pre drilled holes in the frame. So I drilled new holes in the engine block so I wouldn't have to drill more holes in the frame. What is the best way to get the nut to tighten on the inside of block or should I tap hole so I don't have to take engine apart. Also should I use loctite and if so red or blue.
