Yes the 2 extra splines do make a difference as far as axle strength ... how ever that being said take it from me I @%$# up I thought ahh, for temp use I'll freshen up my 7.5 I got the aubern posi really cheap and then picked up a set of 3.73 gears hey not bad $60 -posi $180 - gears like $300 fer axles i dont remember .... Then set it up ( I dont have the tools so I paid a friend ) well new parts lets put in new bearings and seals , then a shim kit . All in all I have about $900 dollars into it and a bad U-joint and drive shaft ate the pinion bearings
lots of work to change pinion bearings everything has to come apart. The jist is for $$$$ spent and time put in I was almost half way to a 9" bolt in and I wouldn't have to worry how long will it last.
Find a beafier rear spend the money there.... Dont waste your time
P.S. mine is still a street car and still has the limp **** 305.
