442 7.5 rear frankenstien.
How did the fluid look in the pan? Make sure you get your governor where you want it or invest in a good shifter for the TH350.
Fluid looked good but I have been adding some here and there. I do have a good three speed shifter for it. So I am covered there. ATF is having a shortage so I cannot afford to fool around or risk not getting any.
There is an ATF shortage?
Reactions: fleming442
Advance Auto was pretty much out of it. They claimed that Castrol makes most of it, and they were shut down for a while. I scored two gallons at Pep Boyz. I also grabbed an edelbrock tv adapter for the tv cable and I hope it works. Also I have this chart from Jegs that says the torque convert should be ok with the rear gears, and the cam ( when I install it) *if
OK Everyone! the trans shift cable has been set commented and set to .840 like I read, the plunger goes in flush at WOT, the trans pan has been cleaned, new filter and new fluid. I did not see any leaks! tomorrow I will pull it out and clean the messy garage, and see how it moves. maybe a test rip if it looks like I can get one in but if not, Saturday we will see.
Feeling great! Sense of accomplishment! Thanks again to everyone that commented, offered guidance and or words of encouragement!
I would say that it definitely helped!
A full second improvement is huge! Very lucky you didn't fry it.
Yeah, my Eyes were huge and my smile was pretty wide! I actually ran a best of 9.11/14.39. And I lifted a little because my 12.00 opponent was way behind me. I only ran 1/8 today and ran a 9.08 This car is going to hit the 8’s before season end!
