The engine overheated last time due to the previous radiator being sh*t. It was frozen solid once, it arrived bent, and I maybe had too high psi of cap. I had a 16lb cap. idk if that was a problem creator. I gave the radiator as scrap to my friend, he took the plastic tanks off and there was some goop in the tubes as well as some were seemingly pinched shut. It blew a headgasket a week after getting to 280 (engine off, was 240~ before I pulled over) on the highway.
the oil pressure problems are unrelated. They stem from that shitty timing cover I got from TA (I've already talked to them about it, they just blamed me for setting it up wrong).
A lot of you seem to be overestimating my "heat" problem. It has a 195 stat in it, and it hangs out at about 210/215 at idle or low speeds. Get going, it will swing back down to 190*actually. Stop, comes back up. I was just wondering if having the 7 blade would eliminate the temp fluctuation. It doesn't overheat, the coolant doesn't percolate after shutdown anymore, the engine runs just as it did the day I rebuilt it a tick over 11,000 miles ago, as if the headgasket never blew.
