7 blade fan good upgrade?
It's got 3/4" tubes. Says it's good to ~525hp on Champions site. I have a little more than half that, so it should be fine once i change the thermostat to a 180 at least.
did you have to translate the Champion site from Chinese to English? Personally I don't have much faith in companies rating their own product unless they have videos of the product being tested.
While I'm glad the solid 4 blade fan worked out for you, Unless somehow this 4 blade is the single greatest cooling accessory ever devised.
Well, it comes stock on a 260 Olds and we all know how great that is.
Must need the cooling capacity 'cause that's one hot powerplant ya know...…...:banana:
I'ma buy up all the 260's I can find, then sell off the fans and retire.
if the temperature rises 20 - 30 degrees at a light and goes back down after take off there is something else going on besides the fan and/or thermostat
Reactions: Longroof79
It doesn't. It just hangs out at 210/215 with the 195, 229v6 5 blade, two year old clutch, and new rad.
what comes stock on a 260 olds? a 4 blade fan?
i'm confused. please clarify.
