7 quart pan in 79 cutlass
1Bad4558
197
16
I'm bout to invest in a milodon 7 quart oil pan for my cutlass. The pan will be going on my 455. I was wondering if I would have any clearance issues with it in my car?
1Bad4558
197
16
Ive done some research on here and other websites and I can't seem to find anything on it. I don't want to do any modifications to the frame or pan for it to fit.
455rocket
242
2
PA
Thats what I have on mine. As long as your using the a body mounts it shouldn't be a problem. Real close on the hood side but even with the frame on the bottom.
1Bad4558
197
16
Okay it's not a problem getting them motor mounts, but why do they need to be used. What is wrong with the stock mounts?
FE3X CLONE
2,714
52
48
Ohio
Nothing. As long as you use engine mounts that match the frame mounts you have the engine will end up in the right place. So if you had a SBO in there before you'll want to use 260/307/350/403 engine mounts.
As for the 7qt. pan you'll be fine. The bottom of the pan will end up about even with the bottom of the engine crossmember.
